Audio Editing Help
Posted by Robert Meadows on July 8, 2008 at 2:29 amHello, I’m trying to figure out how to control the volume level in different sections of my audio without having to constantly split the stream. I want to add ‘points’ to the volume line (if that makes sense) so that I can control the level of volume from one area to the next. Thanks in advance.
Rob
John Rofrano replied 18 years, 2 months ago 6 Members · 13 Replies -
John Rofrano
July 8, 2008 at 3:12 amHi Rob,
You want to add a Volume Envelope to your audio track. You can do this by simply selecting the audio track and pressing the Shift+V key. This will insert a purple/blue volume envelope line. Then Double-Click anywhere along the line to add an envelope point. You can then move the point up and down to adjust the volume.
To raise or lower the volume in just a section make 4 points. The two outside points will maintain the existing volume and the two inner points will create a gradual envelope to the new volume.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Wade Harrington
July 8, 2008 at 3:45 amCan you do this on individual clips and not the entire line of audio? sometimes when moving the line gets really messed up..
Steve Rhoden
July 8, 2008 at 4:23 amUnfortunately the volume envelope cannot be applied to each audio clip,
only the entire timeline. So just use different audio tracks for each
clip that needs the envelope.Steve Rhoden
Creative Director
TNX EFFECTS STUDIOS. -
Wade Harrington
July 8, 2008 at 4:53 amThought so.. Maybe a good idea for a new feature in vegas.. speed Razor used to let you do that. Like the Opacity on the video side of things.
Thanks for the input.
Steve Rhoden
July 8, 2008 at 4:55 amTrust me, you will see that little feature added soon.
Steve Rhoden
Creative Director
Douglas Spotted eagle
July 8, 2008 at 5:02 amOr, you can control the trim of each clip/event individually. Put your cursor at the top of the event, it’ll become a finger. click/drag and it’ll reduce the volume of the event. You cannot increase the gain of the event, however.
Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor -
Robert Meadows
July 9, 2008 at 1:17 amThankyou! Though it would appear you don’t need to push shift.
Aira Vehaskari
July 13, 2008 at 10:57 amHi!
I’m also trying to adjust the volume within a clip, but even though I’ve put in the anchor points and can adjust the line, the volume does not appear to change. No matter how high or low I drag the line, the volume is the same. What am I missing?
thanks,
a -
John Rofrano
July 13, 2008 at 1:29 pmAre you sure you inserted a Volume envelope and not a Pan envelope or FX Automation envelope? Right-click on an empty part of the Audio track, select Insert/Remove Envelope and make sure that Volume Shift+V is checked. If you bring this line down to the bottom the volume should be off. If not, I can’t imagine what is wrong. I use this all the time to edit multiple audio sources for my videos.
~jr
