Activity Forums VEGAS Pro audio editing
  • audio editing
    Posted by Justin Leyba on December 21, 2009 at 10:32 pm
    Is there any noise remover (removes the humming sounds) in sony vegas? And any audio editing tips in Sony Vegas pro 9 will help! thnx!
    John Rofrano replied 16 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    December 22, 2009 at 2:34 am
    If you want to stay with a Vegas filter then I would use the Track EQ that is on every audio track and use the [Sys] 60 Hz hum notch using four stacked filters preset as a starting point. This basically makes a notch filter at 60Hz (of course if you are in PAL land you would want to change this to 50Hz)
    If I were to do this I would use iZotope RX. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
