Audio edit in Vegas 10
Posted by Brad White on November 27, 2011 at 10:48 pmI’m trying to do a simple edit on a small portion of the audio track of a video clip I’m working on in the timeline. Basically, I just want to mute a second or two of the track where someone coughs. I could copy the whole audio track to SoundForge, but SoudForge won’t open the track unless I buy an MPEG codex.
Before Vegas, I was using Roxio and it had the ability to edit audio in the timeline.
Am I missing something basic here?
BradDoyal Gudgel replied 14 years, 9 months ago 4 Members · 9 Replies -
Mike Kujbida
November 27, 2011 at 11:41 pmClick on the audio timeline, press the ‘v’ (volume) key and you’ll see a blue line running the length of your audio track.
Double-click it 4 times, twice at the beginning and twice at the end of the desired location to add points.
Place your cursor between points 2 and 3 and drag them down to the bottom.
Drag points 2 & 3 over so that are right under points 1 & 4 respectively.
In the example below, I left points 2 and 3 up a bit so that you an see what I mean. -
Brad White
November 28, 2011 at 2:20 amThank you Mike. This is exactly what I was looking for. The User Manual doesn’t appear to have an example of how to do this.
I found a less elegant way to mute a segment by using the ‘S’ key; selecting the ‘fader’ across the segment; then dragging the fader curve to the bottom of the track.
Your method is simpler and has more functionality.
Thanks again,
Brad -
Doyal Gudgel
November 28, 2011 at 2:31 amAmazing! I had just signed in to ask the same question.
DG -
Mike Kujbida
November 28, 2011 at 10:54 amTwo for one, today only 🙂
Seriously, I’m glad I was able to help. -
Doyal Gudgel
November 28, 2011 at 7:37 pmWhile I’ve got you in a good mood how can I remove a section of audio and insert audio in it’s place. Video is easy but I am wondering about audio. Anything I do seems to delete both audio and video. I cant isolate audio in a manner to delete that audio. I have a section of bad music I want to replace.
DG
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.com -
Mike Kujbida
November 28, 2011 at 7:48 pmdoyal, I’m always in a good mood 🙂
There are a few ways to do what you want but here’s the easiest.
This assumes that the replacement audio is an audio event, not an audio+video event.
Find the section you want replaced and drop the replacement audio event right over top of it.
Yes, it’s that easy and it works. -
Doyal Gudgel
November 28, 2011 at 10:34 pmOK I will see about making it fit. Thanks
Hope to see you
Danny Hays
December 6, 2011 at 7:35 amYou can ungroup a video event from an audio event by selecting it and hitting the “U” key (ungroup) just like you can group events together by selecting them and hitting the “G” key.
Doyal Gudgel
December 7, 2011 at 2:31 amThanks for the info! Really appreciate it
DGHope to see you
