Activity › Forums › AJA Video Systems › Audio Echoes and unsynked playback on Kona LH with DV
  • Audio Echoes and unsynked playback on Kona LH with DV
    Posted by David Garcia on October 19, 2005 at 5:49 pm
    Hi all,
    We just picked up the Kona LH and I’ve got that warm all over new gear feeling. Want to say first that I like the interface to the software and the hardware (KL BoX) feels real solid.
    We are having a few issues that I’m anticipating working out.
    So here’s what I’m seeing: We are working in DV and monitoring out through the AJA. I’m taking the analog composit out to my monitor. That works fine. The playback on the desktop however is a few frames behind.
    That’s the video, now the audio. The audio through the Kona Monitors is in sync with the video signal out of the card, but out with the desktop video (the desktop video is behind.) Also when I stop the playhead there is an echo where it palys the last few frames of audio again. If I monitor through my Digidesign MBox I don’t get the Audio issue, just on the Kona.
    Also scrolling through the sequence and play start and stop seem sluggish.
    I’ve left a message for tech support, but if anyone knows offhand what I’m seeing I’d appreciate some advice.
    Our system:
    dual 2ghz G5
    8gigs RAM
    2x 200 gb firewire 800 7200 rpm drives
    Aja Kona LH (just for monitoring DV for now)
    Thanks in advance,
    David
    Halflife* Digital
    currently editing
    Plutonium Playground
    http://www.plutoniumplayground.com
    David replied 20 years, 9 months ago 2 Members · 2 Replies
  • David Garcia
    October 19, 2005 at 10:42 pm
    Tech support straightened it out. If anybody’s curious, the audio echo required a firmware update and the playback delay came from a delay setting in the system prefs.
  • David
    December 16, 2005 at 4:12 pm
    David,
    I’m having the same issues but haven’t gotten a resolution yet. I spoke to Kona support, and they reffered me to Apple… no solution. What was the firmware update called? Who did you speak with at AJA to get the right firmware?
    Any help would be appreciated… client coming in next week!!!!
    Dave Phillips
