Activity › Forums › Panasonic Cameras › Audio during variable frame rates and CCD scanning Question
  • Audio during variable frame rates and CCD scanning Question
    Posted by Steve Freebairn on March 17, 2006 at 4:53 pm
    Is it possible to record audio when doing variable framerate recording? Also, is the CCD truly scanning at 24hz or 26 or 22 when set in those different frame rates? I know that it can scan at 60, so there is no problem with 30 fps, but can someone explain how the camera is scanning at 60hz, but recording at 24hz? I know that with pull down that you “have” a place to record the frames, but how is the actual sampling occuring?
    Barry Green replied 20 years, 6 months ago 2 Members · 1 Reply
  • Barry Green
    March 18, 2006 at 1:48 am
    No audio is recorded at all when shooting at variable speeds.
    And yes, the CCD is reclocked and scans at the frame rate dictated in the FRAME RATE menu option.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
