Activity Forums Apple Final Cut Pro Legacy audio during log and capture?
  • audio during log and capture?
    Posted by Quentin Block on December 10, 2006 at 7:52 am
    Hi-
    I’m capturing some random TV stuff from cable to my G4. Cable goes in to a VCR, then out via analog cables to a Canopus ADVC110, then to the computer via firewire.
    While I’m viewing the TV stuff (in real time) in my log and capture window in FCP HD4.5, I can’t hear any audio on the computer. If I ‘capture now’ it seems to work OK and there is audio on the clips. But I can’t hear anything during viewing or capturing.
    I checked the obvious things on my computer like volume and sound settings and things seem ok.
    Any way to hear the sound in my log and capture window, so I can make the best choices of when to capture ‘on the fly’?
    Also: unrelated to sound. When I’m capturing, Will the picture be noticeably or significantly better if I use the s video instead of the ‘yellow’ video input from the vhs to the Canopus?
    Thanks for any advice!
    Quentin Block replied 19 years, 8 months ago 2 Members · 2 Replies
  • Kevin Monahan
    December 10, 2006 at 8:57 am
    In Log and Capture, check the preview button in the audio section of the Clip Settings tab.
    Yes, the SVideo connection would be better.
    This is a basic setup question. Have you checked out Creative Calf?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Quentin Block
    December 10, 2006 at 7:46 pm
    Yes, in the audio section of the Clip Settings tab I tried everything (capturing audio only and aud+vid) and also checked sound settings on my machine before I posted this question. Also tried all the different Audio formats in the Clip Settings tab.
    However, I do not see a specific
