Activity › Forums › Apple Final Cut Pro Legacy › Audio drops when exported as QT movie…
Posted by Chandler on January 21, 2006 at 5:59 pmOnly in some spots…why? is it because I am using a firewire connection?
Randyp replied 20 years, 8 months ago 4 Members · 3 Replies -
Matthew Brunn
January 21, 2006 at 6:14 pmExport your timline as a self-contained movie and import, then export that over firewire and see how that works. Sounds like your drives are not up to the challege.
Hope this helps-
Matthew
Dual 500 G4
OSX 10.3.9
Ram 1.38
FCP 4.5/AE 6.5/DVDSP3 -
Debe
January 21, 2006 at 6:40 pmAlso try an audio mixdown of the audio. That’s OPT+CMD+R. Even if you only have one track, it can be helpful with dropped frame and mysteriously disappearing audio issues. It’s a render file that’s created, not a new media file like in Avid. Just hit OPT+CMD+R and let it go, as soon as it’s done processing, you are good to go. No importing or exporting necessary.
However, if the mixdown alone doesn’t work, the above suggestion after mixing down would be the next best option to try.
debe
Randyp
February 1, 2006 at 9:15 pm[debe] “Also try an audio mixdown of the audio. That’s OPT+CMD+R. Even if you only have one track, it can be helpful with dropped frame and mysteriously disappearing audio issues.”
I’ve also experienced the audio drop-out problem when exporting a QuickTime Movie from my FCP project. At one point along the timeline the soundtrack is busy with layers of music and several sports sound effects. The sound effects would drop out or the music or both at that point. A co-worker suggested the audio mixdown, as mentioned above, which solved the problem for me.
Randy
“You are:
1. Untalented but excessively persistent
2. Unbelieveably stupid
3. An artist
4. All of the above”–Norman Rockwell
