Activity Forums Adobe Premiere Pro audio drops when editing. .
  • audio drops when editing. .
    Posted by Brad Foubister on May 13, 2008 at 9:45 pm
    Premiere Pro CS3.
    I playback/preview the edited area to find the audio is dropping every few seconds.
    the audio bar shows there is sound there, and when I move the start position ahead or behind the previous position the places where the sound drops out are different as well.
    Any solutions?
    Brad Foubister replied 18 years, 4 months ago 2 Members · 4 Replies
  • Jon Barrie
    May 14, 2008 at 2:38 am
    what kind of audio file is it? mp3?
    they have problems.
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Brad Foubister
    May 14, 2008 at 4:40 pm
    Hi Jon,
    first off, thanks loads for a simple direct answer and not some link to ‘go read the rules and post your details’ like I get on adobeforums.
    The music file is .wav but the audio from the video is .mpeg
    And I seem to be having trouble with both.
    If it’s just a ‘glitch’ on playback that works itself out when rendered and saved then I can put up with it.
    But, obviously it’s something that should be fixed.
    Great showreel, by the way.
    I aspire and press on
  • Jon Barrie
    May 15, 2008 at 2:51 am
    Mpeg as in from DVD or such, will cause issues. Take the audio only from the MPeg sources and render out the audio into a WAV format, but opening the files in the source monitor, then file>export>Audio
    Reimport them into PProCS3 and use the replace function you should have no more problems.
    – Jon 😉
  • Brad Foubister
    May 15, 2008 at 4:01 pm
    Thank you again, Jon.
    Good advice. Will do.
    -Brad
    http://www.Studio-Era.com
