Audio dropping out
I am working on a project using Final cut pro 5.1 and am having problems with the audio dropping out every now and then. It quite a big project and I need to fix this problem. I have asked elsewhere and somepeople said that it could be a driver issue between Quick Time and Final Cut having recently upgraded to Quicktime 7. Has anyone else come across this problem before or have an alternative solution or know which quicktime is best suited to Final Cut 5 and how big a job is is to uninstall quicktime? Your help is much appreciated
Brian
