Activity › Forums › Apple Final Cut Pro Legacy › audio dropouts on Quicktime
Posted by Robyn Symon on July 5, 2005 at 7:34 pmHi,
I have a timeline made up of six subsequences totally an hour. When I make a quicktime movie, I have audio dropouts for as long as ten minutes until the next subsequence begins. Sometimes in the middle of a sequence the audio cuts out. If I make a movie of just one subsequence, the audio is fine. Thanks.Thaxter Clavemarlton replied 21 years, 2 months ago 2 Members · 3 Replies -
July 6, 2005 at 12:22 amQuestions like this are posted very frequently. And many (most?) of the problems are solved by a simple procedure.
There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs or freezes.
NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
Sequence Menu > Render Only > Mixdown.
You should see a dialog box telling you its rendering.
It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
Robyn Symon
July 6, 2005 at 1:38 amThanks so much!!
I did the mixdown and it worked. No audio dropouts. Should I be doing the export through conversion (batch) rather than the quicktime movie for better quality? If so, how. By the way, I do see blue lines above the time line. Does that mean anything? robyn -
July 6, 2005 at 2:43 am[symonprod] “I did the mixdown and it worked.”
It usually does the trick. Its just so easy to overlook.
[symonprod] “Should I be doing the export through conversion (batch) rather than the quicktime movie for better quality?”
No reason to do that.
[symonprod] “I do see blue lines above the time line. Does that mean anything?”
Blue lines just indicate that section has been rendered.
