Activity Forums Apple Final Cut Pro Legacy audio dropout?
  • Posted by Thunkgrass on September 14, 2005 at 9:25 pm
    hi there,
    i am shooting on a PD150. the audio on my tapes are clean good quality. when i capture them into fcp using wither a dsr 2000, dsr 20, or a dsr 11 the audio monitored out of the deck is clean, but after capture when i play the clip back in the viewer or in the timeline i get get audio dropout and clicks and pops. any ideas?
    thanks
    -travis
    Nick Price replied 21 years ago 3 Members · 4 Replies
  • Kevin Monahan
    September 14, 2005 at 9:41 pm
    You capture settings and sequence settings are not matching. Find out if you shot 32 kHz or 48kHz and then match the capture settings and sequence settings to that.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Thunkgrass
    September 14, 2005 at 10:01 pm
    Thanks for the input, but no luck, all the presets match up.
  • Kevin Monahan
    September 14, 2005 at 11:59 pm
    Which version of FCP? Also, try an audio mixdown.
    Kevin Monahan
    fcpworld.com
  • Nick Price
    September 16, 2005 at 1:39 pm
    This also happens when capturing via firewire. Apparently in the audio settings, the speaker needs to be turned off, otherwise you get these clicks and pops. Although it doesnt seem to matter if the speaker is on or off for me…..
    nick
