Activity Forums Apple Final Cut Pro Legacy audio dropout caused by video channel
  • audio dropout caused by video channel
    Posted by Peter Ralph on March 24, 2008 at 1:56 pm
    FCP 5 – SD video
    Playing thru a clip on the timeline the audio cuts out for a couple of seconds. Zooming in to the timeline I see a 1 frame dropout on both audio channels. I cut out that frame. But the audio still disappears.
    I razor the video and isolate the video frame immediately prior to the audio dropout. Pull the opacity down to 0 and the audio plays fine. Take the opacity on that single frame back up and the audio drops out again.
    It’s easy to fix by copying the frame to another sequence and thenput the single frame sequence back into the original timeline, but anyone konw what is happening?
    thanks
    I am not sure whether this problem is on the original tape, as I don’t have it
    James Serikawa replied 18 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    March 24, 2008 at 4:23 pm
    Delete all of your render frames (audio and video) and try again.
    Jeremy
  • Peter Ralph
    March 24, 2008 at 5:14 pm
    no render frames involved – the problem (2 sec audio dropout) was there on capture.
  • Arnie Schlissel
    March 24, 2008 at 6:43 pm
    What’s happening in the picture on that frame? Is there something like a dropout, or a camera flash going off in the lens?
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Peter Ralph
    March 24, 2008 at 9:23 pm
    no – it occurs half-way thru a 10 minute looked down shot with little movement. Nothing starnge about the frame in the scopes
  • Arnie Schlissel
    March 25, 2008 at 12:08 am
    That’s pretty odd. I could see if there was a dropout or if the chroma or luma suddenly spiked, but now you’ve got me stumped. Are you able to check the original source tape?
    Arnie
  • Peter Ralph
    March 25, 2008 at 11:01 pm
    I no longer have the tape – it’s possible that the frame was corrupted somehow on capture –
    oh well, an easy fix thankfully
  • James Serikawa
    March 27, 2008 at 10:25 pm
    Just out of curiousity, what camera was used? We seem to be having a similar issure with an XL-1.
