Activity Forums AJA Video Systems Audio Drop outs and Timecode breaks..
  • Audio Drop outs and Timecode breaks..
    Posted by Deyson Ortiz on June 17, 2005 at 1:56 am
    The major problem I am having is I keep hearing audio drop outs in the capture,
    and the second I have timecode break errors, where there is no time code breaks.
    any Ideas?
    the biggest problem are the audio drop outs. the timecode problem I could always do a capture now..
    Capturing 1080i as DVCpro HD
    on a dual 2.7 tiger.
    on Kona 2
    with FInal cut 5
    I am tired, and solution would be wonderful.
    don’t feel like pulling a 20 hour day.
    Gracias
    Jeremy Garchow replied 21 years, 2 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    June 17, 2005 at 3:27 am
    What kind of audio drop outs are you getting? Are you coming in embedded or AES/EBU? Are you just hearing them during capture or are they in the QT file after capture?
    As for the timecode breaks, it seems to be a problem. I just finished four long 720p60 videos and I was getting so sick of the timecode breaks, I turned off the warning in FCP preferences. SOme people might find this unorthodox, but you can tell FCP to warn you of timecode breaks after capture (and not to make a new clip), and it seemed to work great for me. If this is too risky for you, simply hit escape when FCP is ‘searching for timecode break’ and then continue to capture. Most likely it will try and recapture the clip that supposedly had the timecode break without incident. I just reread that you are in FCP 5, I was using FCP 4.5. I hope there is still a preference to turn off the timecode break warnings.
    Hope this helps.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Kent Harrell
    June 17, 2005 at 6:00 am
    I am capturing with the Audio inbeded, but I just noticed a warning 02 on the deck “lost Lock” when the audio drops out, don’t know what it means,, it happend randomly.
    I’m going to do a search on exactly that means…
    I’m going to do the warn after capture..
    thanks…
  • Kent Harrell
    June 17, 2005 at 6:04 am
    That was Deyson that replied, not Kent,, sorry.. late night and different computer and forgot my password.. to late to search..
    thanks
    Deyson
  • Jeremy Garchow
    June 17, 2005 at 10:58 pm
    I don’t know what deck you are using, but it sounds like a sync issue to me.
    Jeremy
