Activity Forums Apple Final Cut Pro Legacy Audio drop out with nested sequence
  • Audio drop out with nested sequence
    Posted by Jessica Buritica on January 16, 2008 at 4:16 pm
    Im working on a project and using a nested sequence that has a music track under it in the MAIN SEQUENCE. When I do playback on the main sequence, the music drops out under the nested sequence.
    My temp fix is to re-render, it sometimes works and sometimes (out of no where) starts again.
    Any suggestions?
    using FCP 6.0.2
    thanks
    Jessica Buritica replied 18 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    January 16, 2008 at 11:00 pm
  • Jessica Buritica
    January 17, 2008 at 3:39 pm
    Its an interesting post, but I don’t have the exact same issue. The audio that does manage to play back is in sync and correct, its just that (when playing back from the main sequence) the underlying music is dropped out where there are gaps in the vo audio if that makes sense.
