Activity › Forums › Adobe Premiere Pro › Audio Drop Out Issue
  • Audio Drop Out Issue
    Posted by Stokes Mcintyre on August 16, 2011 at 1:29 pm
    Hi Everyone,
    I have a simple, two channel audio track. Towards the end of the track the audio drops out and I get this error…
    [/Volumes/BuildDisk/builds/Mulder64/shared/adobe/MediaCore/AudioRenderer/Make/Mac/../../Src/AudioRender/AudioPrefetch.cpp-87]
    I noticed that in the timeline the little green render bar stops about where the audio drops out. When I export the audio the drop out remains in the audio.
    I’m on a MAC, LION
    Robert Ober replied 15 years, 1 month ago 2 Members · 3 Replies
  • Robert Ober
    August 16, 2011 at 10:55 pm
    [stokes mcintyre] “I noticed that in the timeline the little green render bar stops about where the audio drops out. When I export the audio the drop out remains in the audio.”
    Does the original file have a dropout if you play it the Quicktime player? What format is the original audio file and what audio format are you using for your timeline?
    Robert
  • Stokes Mcintyre
    August 17, 2011 at 8:10 pm
    Hi Robert,
    Thanks for the response.
    I tested playing the audio file using quicktime and it did not drop out.. it played fine.
    The audio format is WAV.
    I am not actually sure what audio format I am using in the timeline. I didn’t know I could set that. I just imported the WAV files. I apologize for my ignorance. I’ve recently defected from FCP.
    Stokes
  • Robert Ober
    August 20, 2011 at 2:18 am
    On a Mac, wav would be unusual. If you open it in Quicktime the Inspector window should tell you what the codec is. Premiere should have no problem unless it is a really odd codec, but some editors do not like certain codecs they pretend to support. For instance, FCP does not like MP3 as I recall. I would convert the wav(s) to pcm(uncompressed) aiff.
    Good Luck,
    Robert
