Activity Forums Adobe Premiere Pro Audio Drivers on re-install
  • Audio Drivers on re-install
    Posted by Julie Allen on June 7, 2007 at 7:47 pm
    Thanks to all of you for your help with teaching me how to export straight for YouTube. Our client loves it, so I’m stuck with it.
    On another note – we just upgraded to a new motherboard and processor last night. Now, Premiere (after having to re-install it) says it couldn’t load any audio drivers??????
    Huh?
    Thank you in advance.
    I’m I’m already looking for some to download. Any good locations you can recommend?
    Vince Becquiot replied 19 years, 3 months ago 3 Members · 3 Replies
  • Vince Becquiot
    June 7, 2007 at 11:02 pm
    Well, if the motherboard has onboard audio, that would make sense. You just need to install those drivers as well.
    Vince
  • Blast1
    June 8, 2007 at 12:23 am
    Did you load the drivers like Vincent mentioned? If you already have check the disk you loaded from and see if there is a directory for ASIO drivers, if so load them, if not you can download a driver called “ASIO4ALL” and load that.
  • Vince Becquiot
    June 8, 2007 at 4:30 am
    And one more thing, if this not an on board card, you’ll probably have to reinstall the drivers anyway, since I’m assuming the IRQ’s will be different.
    Vince
