Audio Drifts Out of Sync
I am at a loss. I have several .avi files that I am trying to convert to .m2v’s in order to create a DVD in Encore. The original avi’s play fine all the way through with no audio syncing issues but everytime I try to transcode them or convert them to a different format the audio slowly drifts out of sync usually becoming most noticeable toward the end of the video.
I have tried everything I can think of short of going through all the codecs one by one and hopping one hold the sync.
I’ve tried converting to an Uncompressed AVI, to an MP4, to an M2V. I’ve tried matching the kilohertz and changing the kilohertz. I’ve tried exporting audio only from Premiere. I’ve tried to let Encore handle the encoding. I even tried using VLC media player to convert them once I got desparate. I also found a few different forums – some here on Creative Cow – that talk about exporting as a certain format then converting that file to an m2v. Nothing is working!
Here are the properties from one of the problematic AVI files:
Type: AVI Movie
File Size: 174.4 MB
Image Size: 624 x 352
Frame Rate: 23.97
Source Audio Format: 48000 Hz – 16 bit – Stereo
Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
Total Duration: 00;21;23;15
Average Data Rate: 139 KB / second
Pixel Aspect Ratio: 1.0The files vary in video data rate, video total bitrate and in audio bitrate but none of them will sync properly when I try to encode them. Does it have anything to do with the descrepancy between source and project audio format as seen above? Is there something else inside that pesky AVI container that is screwing me up?
I am no encoding expert by any means so if someone could please shed some light on this for me it would bring me a world of peace. Thanks in advance.
