Activity Forums AJA Video Systems audio drifting with Kona LH
  • audio drifting with Kona LH
    Posted by David Garcia on April 4, 2006 at 4:29 pm
    I am outputting an hour and 40 minute piece in DVCPRO HD from FCP 5 via our Kona LH. The audio drifts out of sync after about 5 minutes (which is also after the first cut) The piece is just ra footage brought in off of P2. It’s a window dub, so the edits are very rudimentary. I just pieced a bunch of stuff together.
    The footage is 720p 24 but the video output is KonaLH 59.97 720 8bit. Could this be the problem?
    Other info: dual 2ghz G5. Lacie S2s 1 TB in Raid 0. Outputing via Kbox using downconvert to JVC DVD recorder.
    The guy at AJA told me he thought the Lacie might be too slow, but I could swear I’ve worked on other stuff that was more complicated that I’ve not seen this drift on.
    Any thoughts are greatly appreciated.
    David
    david garcia
    Halflife* Digital
    albuquerque, nm
    David Garcia replied 20 years, 5 months ago 2 Members · 2 Replies
  • David Battistella
    April 4, 2006 at 9:07 pm
    I have seen this on long tape captures but I haven’t heard of this from P2.
    Are the files playing in sync in the viewer (if they are not in the timeline)?
    Have you tried making a 1 or two frame edit on the first cut? (call me crazy but I have seen this work many times)
    David
    Peace and Love 🙂
  • David Garcia
    April 5, 2006 at 12:53 am
    I’m going to check this stuff out. The issue is not the file or the timeline. The clips are inn sync, the audio just wanders on playback. I wound up using compressor and DVD studio pro to author the DVD, but it took 5 hours instead of the hour and a half it should have.
    The AJA guy said my ESATA hard drive might not be fast enough. That would be a drag.
    thanks for the advice.
    David
