Activity Forums Adobe Premiere Pro Audio drifting out of sync
  • Audio drifting out of sync
    Posted by Mitch Jordan on August 19, 2013 at 6:48 pm
    I’m new to Premiere Pro having recently converted from Final Cut Pro. I have a half hour documentary edited in 4 segments- Quicktime files, H264, 720P. I want to lay them on the timeline and play the entire show out to tape (actually XDCAM Disk). I really start to see the audio drifting out of sync about halfway through the program, and it continues to get worse. Does anyone know what is going on? I’d like to Print to Tape, as in FCP, but I can’t find that command. I’m playing it out of the timeline at full resolution. Is there a better workflow?
    My computer is a Mac Pro, OS 10.7.5, and I’m running Premiere Pro CC 7.0.1. Thanks.
    Paul Neumann replied 13 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • Kevin Monahan
    August 19, 2013 at 8:36 pm
    Hi Mitch,
    Is the media playing off a dedicated media drive?
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Mitch Jordan
    August 19, 2013 at 9:16 pm
    Yes, we have a Terrablock server connected by fiber to the edit bays.
  • Kevin Monahan
    August 19, 2013 at 9:51 pm
    Hi MItch,
    What about the source footage? Does the source footage match the sequence settings precisely? Does any of the source video have a variable frame rate (common in iPhone H.264 files)?
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Mitch Jordan
    August 19, 2013 at 10:05 pm
    I received the files from a post house, so they don’t have a variable frame rate like an iPhone. They edited the show and sent us the .mov’s. I started by dragging segment 1 to the new item icon to create the sequence and then I added the remaining 3 segments. I am exporting through a Matrox MXO LE, but the files appear out of sync even on my computer monitor not just on my broadcast monitors.
  • Chris Borjis
    August 19, 2013 at 10:22 pm
    Mitch, when you imported the files, did you allow premiere the time
    it needed to conform all the files, before you began editing?
    (in the lower right below the volume level guages)
    It’s important to do nothing until that completes.
    doing so can result in out of sync audio.
  • Mitch Jordan
    August 19, 2013 at 10:29 pm
    I don’t know if I did. I’m used to jumping right in aka FCP. Also, I’ve been looking at the Audio Sample Rate. The clips came in at 44100hz. The sample rate is correct when I check my sequences settings, but can I trust that Premiere Pro adjusted it correctly? I’ll try to reimport the clips and make sure it has time to conform.
  • Mitch Jordan
    August 19, 2013 at 10:35 pm
    Well, I just re-imported the footage, and I never saw Premiere Pro conform the files. Does it always do that?
  • Chris Borjis
    August 19, 2013 at 10:37 pm
    it does.
    part of the process to make editing possible with any type of footage
    without having to transcode.
  • Paul Neumann
    August 20, 2013 at 3:54 am
    Matrox + h.264 nearly always gave me sync problems. To the point I turfed the whole set-up and just went native.
