Activity Forums DaVinci Resolve Audio drifting
  • Audio drifting
    Posted by Gareth Cook on January 22, 2011 at 4:38 pm
    Good morning All,
    I did a conform with Red files and picture matches offline, i added the audio file and it starts in sync and over time drifts out of sync. The footage is about 14min long. Anybody else have this problem? Any thoughts?
    Gareth
    Gareth Cook replied 15 years, 8 months ago 5 Members · 5 Replies
  • Kevin Cannon
    January 22, 2011 at 5:14 pm
    If the source footage and the audio are the same frame rate (e.g. 23.98&23.98 or 24&24 etc.) and it still drifts, check the “monitoring” section on the config tab, I’ve found it also needs to be set to that frame rate…
    KC
    prehistoricdigital.com
    hardworkingpixels.com
  • Sascha Haber
    January 22, 2011 at 6:13 pm
    Would be nice if we could set all available fps settings, globally, for all four windows and with a simple dropdown tab
    Like 23,976 for example
    A slice of color…
    DaVinci 7.1 OSX 10.6.6
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Margus Voll
    January 22, 2011 at 6:21 pm
    are you sure that imported audio is 48 khz ?
    Margus
    https://iconstudios.eu
  • Rohit Gupta
    January 23, 2011 at 10:00 am
    This sounds like a 23.976/24 problem. There’s a quick way to check this.
    Set the video monitoring to 24sF, see if you have the problem. If yes, set it to 23.98sF (leave the play speed at 24 — Resolve will still play it at the native speed of 23.976).
    Once you have identified this, you might need to slow down or speed up the audio to match the video playback speed.
  • Gareth Cook
    January 24, 2011 at 4:48 am
    Thanks Rohit,
    It was a monitor problem, all Resolved.
    Gareth
