  • Zach Macdonald
    May 13, 2005 at 7:38 pm
    Rich –
    Just opened up FCP to check it out and it looks to me like there is in fact 48000.00 kHz Sample rate available.
    Options > Sample rate > 48000.00.
    Zach
  • Rich Rubasch
    May 13, 2005 at 8:16 pm
    I can only set a 44.1k sample rate! What broke? QT 6.5, OS 10.3.9…FCP HD Dual 1gig G4.
    Rich
  • Rich Rubasch
    May 13, 2005 at 8:27 pm
    Sure enough…If I set the AV device to none and I select the audio to built in, I only get a 44.1 sample rate. If I change the AV output to Firewire I get a 48k and a 32k choice. But under the output to tape is different setting, if I choose none I still only get a 44.1k setting.
    Rich
  • Bouncing Account needs new email address
    May 13, 2005 at 10:03 pm
    “Built-in” in this case means the Macintosh Computer’s audio play system.
    It has nothing to do with FCP’s “built-in” audio settings.
    The Mac internal “top-end” only offers 44.1 kHz, but if you buy a 3rd party audio device (like a Griffin “iMic” USB audio adapter) you will then be offered the 48 kHz option.
