Activity Forums Adobe Media Encoder Audio drift in blu-ray project
  • Audio drift in blu-ray project
    Posted by Paul Levering on February 8, 2013 at 9:51 pm
    Greetings! I’m having trouble finding a solution to this issue, though i see people complain about it in quite a few threads around the net.
    I’m in the process of authoring a Blu-ray project. Footage was shot on the Panasonic AF-100 in 24fps 1080p. Footage is edited in FCPX in a 23.98 timeline, exported as a self contained. Self contained is taken to AME, exported using
    H.264 Blu-Ray (Legacy)
    MainConcept H.264 video
    All settings automatic
    Profile is Main
    Level is 4.1
    Render at maximum depth
    VBR, 2 Pass
    target Mbps 15
    Max Mbps 20
    Keyframe is unchecked
    Max render quality is checked
    Frame blending is unchecked
    I tried a few tests before going with these settings, and at first it seemed like my exports were good. I burned out test discs and tried on a few different player models, all seemed fine. I did notice my audio was slightly longer than the video in the sequence for my test builds.
    As I moved on to compressing a longer video (114min) I realized the audio was sliding out of sync badly. Comparing the exported video to my source self-contained, it’s shorter by a few seconds while the audio file is still the same length as the source.
    The best I can figure is the 23.98 footage is being converted to 23.976 and dropping a few frames, although I keep seeing people say 23.98 and 23.976 are the same thing. Any idea how to deal with this problem?
    Paul Levering replied 13 years, 6 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 8, 2013 at 10:29 pm
    23.98 is merely how 23.976 is represented by software that can’t show three places after decimal point. Never use 23.98 as a frame rate. If you do, then you will encounter frame rate mismatches like the one that you’re experiencing.
    After Effects team blog
  • Paul Levering
    February 8, 2013 at 10:43 pm
    OK, so is there a solution to the problem or no?
