Activity Forums Apple Final Cut Pro Audio Drift
  • Audio Drift
    Posted by Gerry Fraiberg on November 9, 2011 at 2:56 am
    I am editing a 56 minute wedding video event consisting of speeches, and it appears audio is out of sync while video is rendering. Audio was recorded on a Sony Z5U with a Sennheiser wireless on podium, and Sennheiser ME66 on camera, separate channels. I used FCP7 to ingest clips and then copied the files into FCPX. The Channel Configuration is Custom [L,R] and I changed to Dual Mono, then turned off the camera mic to cut room echo. Now I see (and hear) that the audio has drifted out of sync. I have placed a Cross Dissolve using Full Overlap between each clip. The original clips appear to be in sync when played from the Finder.
    I have applied CrumplePo Finisher to all clips. I should note that the out of sync clips are still rendering. Clips at the head end that have already rendered look like they’re in sync. Is this a symptom of the image rendering? I should mention that I sent an email to Gabe at CrumplePop just as an observation that rendering is taking a long time. Gabe replied that Finisher is doing a lot of processing to each frame.
    Any thoughts or suggestions?
    Gerry
    Bill Sandifer replied 14 years, 6 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    November 9, 2011 at 3:02 am
    I’d wait to see when it finishes to see if it’s still out of sync.
  • Gerry Fraiberg
    November 9, 2011 at 3:12 am
    Thanks. I had a moment or two of panic. I’ll have to leave the machine running to render the event. I’ll report in the morning. Yes, it looks like it’s going to take a long time.
    From the CrumplePop web site:
    Finisher’s unique Depth control expands apparent latitude via an additive process that is applied to multiple keyed layers.
    So while FCP X is fast, there’s a lot going on in the background.
  • Bill Sandifer
    February 13, 2012 at 5:18 am
    I’m having drift problems with simple capture of video/audio from my XHA1 and a Nikon P7000. At first it was in sync (after abandoning iMovie for FCPX) and now I’m unable to get any concurrently shot video/audio to sync, in preview or after rendering. Is there no hope?
