Activity Forums Apple Final Cut Pro Legacy Audio Drags on XDCAM video
  • Audio Drags on XDCAM video
    Posted by Natalie Raichl on December 7, 2015 at 5:50 pm
    Hi:
    I’m using FCP 7 to edit video we shot on XDCAM EX 1080p30 35mbs (variable). Our client sent us some footage shot on XDCAM HD422 1080p30 50mbs, and, for the life of me, I can’t get the audio to stay in sync. I dropped it into a sequence with the same properties as what was shot, but the audio drags. I tried using Compressor to convert it to the same XDCAM EX we were using, but to no avail. I tried converting to ProRes, and it got worse. If i look at the file on my desktop, and preview it by hitting the spacebar, it seems to play fine, but when I open in Quicktime, or import to FCP, the lip sync drifts off. What am I doing wrong?
    MacBook Pro, OS X Mavericks (10.9.4), FCP 7, Compressor 4
    Kevin
    Nick Meyers replied 10 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mark Suszko
    December 7, 2015 at 5:55 pm
    Audio sample rates don’t match?
  • Natalie Raichl
    December 7, 2015 at 6:27 pm
    I matched the sequence to the clip. 24 bit audio, channel grouped.
    Kevin
  • Mark Suszko
    December 7, 2015 at 6:30 pm
    Go back thru the timeline settings and re-set them manually, making sure the audio sample rates agree. If you have a frame rate mis-match, that may not help you.
  • Natalie Raichl
    December 7, 2015 at 7:00 pm
    Tried that, to no avail. When I open it in quicktime, it plays OK until I try to skip ahead a minute, then it gets out of sync. I looked at the attributes, then created a sequence to match that. 29.97, 16 bit audio 48khz. Didn’t work. This is crazy.
    Kevin
  • Greg Ball
    December 7, 2015 at 8:17 pm
    Have you had success running FCP 7 on OS X Mavericks (10.9.4) before this?I’ve heard that FCP does bot run well on Mavericks
  • Natalie Raichl
    December 7, 2015 at 8:41 pm
    Yep. I’ve been running FCP on Mavericks for several months now. No problems at all.
    Kevin
  • Nick Meyers
    December 8, 2015 at 1:30 am
    are you saying that when you open the original file in Quicktime it plays out of sync?
    can you open it in Sony’s XDCam transfer software?
    nick
