Activity Forums Apple Final Cut Pro Legacy audio doesn’t work
  • audio doesn’t work
    Posted by Mari Lopes on January 20, 2008 at 6:51 pm
    Hello There!
    I’m new in this forum, and also a new final cut user, so probably will need loads of help and i’ll really appreciate you for that! 🙂
    The first one:
    I have some clips recorded from a photo-camera and they play normally when using quicktime, but after imported into final cut they seem that the audio simply doesn’t exist. I’ve already saved the mpegs files into .mov, but still the same.
    What should i do???
    Mari Lopes replied 18 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    January 20, 2008 at 7:01 pm
    What Easy Setup are you using?
    Ensure that FCP is set to playback the audio to the proper monitors. That is, either to your internal audio or to an external device such as your camera.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Mari Lopes
    January 20, 2008 at 7:48 pm
    Well, I haven’t chosen one, but what it says is:
    Format: PAL
    Use: Custom Setup
    Seq Preset and Capture Presset: DV PAL 48 Khz
    Device control preset: FireWire PAL
    Playback output Video: None
    Playback output Audio: Built-in output
    Is this what you’re asking?
    Thank you very much 🙂
  • Walter Biscardi
    January 20, 2008 at 8:00 pm
    [Mari Lopes] “Is this what you’re asking?”
    Yep.
    Since you have Built In Output chosen, you should hear the audio through your speakers. If you don’t, make sure any other software that might use the speakers is turned off. Such as iTunes, Quicktime Player, DVD Player, etc…
    Read my Blog!
  • Mari Lopes
    January 20, 2008 at 8:18 pm
    still not working… 🙁
    and i’ve just realised that the audio doesn’t even show on the tab on the top of the viewer…
    any other suggestion?
    i hope i’m not bugging you 😉
    Thanks so much!!!!!
  • Walter Biscardi
    January 20, 2008 at 9:45 pm
    [Mari Lopes] “and i’ve just realised that the audio doesn’t even show on the tab on the top of the viewer…”
    So you don’t see any audio tabs in the Viewer? Then there is no video associate with that clip. You have a Video Only clip.
    Read my Blog!
  • Walter Biscardi
    January 20, 2008 at 10:38 pm
    [Mari Lopes]
    i hope i’m not bugging you ;)”
    Missed that before, nope, no bother. That’s what we’re here for! 🙂
    Read my Blog!
  • Mari Lopes
    January 22, 2008 at 12:05 am
    It might be a problem with the files, cause as i said before, when i play them using quicktime, they work normally – with the sound.
    I tested importing similar files into the same project and all of them worked well.
    Thank you for your help!
    I’ll be back! 😉
