Activity Forums Avid Media Composer Audio distorts when I export from Avid MC
  • Audio distorts when I export from Avid MC
    Posted by Megan Oldfield on May 11, 2014 at 10:32 pm
    I am working in a 23.98 frame rate project. It’s DSLR footage. I export the audio for protools and the audio gets cleaned up by our mixer. They send me a wave file that is 48Hkz and 24 bit. I cut that in an replace the existing audio. So the only audio left in the time line is the new cleaned up wave file.
    My project is set for these same audio parameters (48Khz and 24 bit). When I export the project with the cleaned up audio, there is a harshness to the audio portion of the program that is not present when I play the audio in the timeline.
    I have exported the project with sorenson settings (quicktime reference movie), I have exported same as source (with and without avid codecs selected) and no matter what I do the audio sounds harsher than the wave file I receive.
    I am not sure what settings are conflicting or how to correct this problem.
    I am in MC 7.0.2
    audio project settings are:
    Sample rate: 48Khz
    Audio file format: Wave
    Bit Depth: 24 bit
    DV Audio Pattern: Unlocked Audio
    Convert Sample rate when playing: Always
    Show mismatched sample rates…: yes
    Remove extra filler…: Keep
    Any advice would be greatly appreciated.
    Neil Ryan replied 12 years, 4 months ago 4 Members · 4 Replies
  • Job Ter burg
    May 12, 2014 at 6:02 pm
    Check the pannings. If you are center panning a pair of tracks that is meant for stereo playback, levels will be summed.
  • Megan Oldfield
    May 12, 2014 at 10:52 pm
    Thank you. That was it. Literally music to my ears.
  • John Pale
    May 13, 2014 at 1:08 am
    Your default audio settings may be set to center pan. You might want to change this, to prevent future problems.
  • Neil Ryan
    May 13, 2014 at 6:23 am
    And consider looking at the Audio tab of your export settings and setting it to Direct Out.
    Neil.
