Activity › Forums › Apple Final Cut Pro Legacy › audio distortion
  • audio distortion
    Posted by Mark023 on February 2, 2006 at 2:40 pm
    What is the best way to try to correct audio distortion (in FCP5 or Soundtrack Pro) from a lapel mike that had the volume turned up too high? It’s not real bad, but I want to try and get rid of the small amount of distortion.
    Thank you.
    Mark
    Mark023 replied 20 years, 7 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    February 2, 2006 at 2:56 pm
    Don’t think it can be done I’m afraid. It’s akin to over exposure. Might play around with some eq filters but…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Chris Poisson
    February 2, 2006 at 3:16 pm
    Mark,
    Actually, it can be done if the distortion is not too bad, I’ve done it with the low pass filter. Not perfect, but it helps.
    Have a wonderful day.
  • Mark023
    February 2, 2006 at 6:37 pm
    Thank you,
    Mark
