Activity › Forums › Apple Final Cut Pro › Audio distortion when I share to any file type (Master File, Apple Devices 4K…)
  • Audio distortion when I share to any file type (Master File, Apple Devices 4K…)
    Posted by Meg Mangum on March 9, 2018 at 3:17 am
    When I listen to my project video within Final Cut Pro X, the audio settings are working fine and the sound is perfect. When I share it to all of the different options available to me, the audio sounds horrible (loud and lots of static). I don’t see any options in the “share” menus that allow me to choose any sound settings. Can I fix this? If so, how??
    Brett Sherman replied 8 years, 6 months ago 2 Members · 1 Reply
  • Brett Sherman
    March 9, 2018 at 12:25 pm
    That is really puzzling. Is it possible that you “disabled” or muted audio tracks in the timeline (so they are greyed out)? I’ve found they still output when sharing in that case. Instead you can silence them by dropping audio level all the way down. Or uncheck the audio channels in the Inspector.
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
