Activity Forums Adobe Premiere Pro Audio distortion when exporting WMVHD from HDV timeline
  • Audio distortion when exporting WMVHD from HDV timeline
    Posted by Payner44 on January 5, 2007 at 9:59 pm
    When I export an HDV timeline using the WMVHD codec the resultant audio sounds overmodulated. My timeline audio is a single stereo track set at 0db. I’ve tried export bitrates from 96k to 256k with the same result. Video looks just fine. Any suggestions for getting better results?
    Payner44 replied 19 years, 8 months ago 4 Members · 6 Replies
  • Harm Millaard
    January 6, 2007 at 7:26 pm
    Set audio to -12 or -6 dB max.
  • Payner44
    January 6, 2007 at 7:33 pm
    I normally do as you suggest when I have a voice over track in use. I should have mentioned earlier that exporting the timeline as MPEG 2 for DVD does not distort the audio…same goes for encoding in the DivX HD format. Only WMVHD exibits this behaviour. So, your suggestion is simply a work around? Or is this how you must conform in order to use WMVHD?
  • Tim Kolb
    January 6, 2007 at 8:04 pm
    I’m not sure i understand…if you normally set peak to -6 or -12, why did you set this audio to peak at zero? This allows for absolutely no headroom for transients.
    There are different standards for setting levels for digital audio…one I keep hearing is -20dB or -18dB…I personally think that leaves a lot of unused audo bits. I set for -12dB.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Payner44
    January 6, 2007 at 8:25 pm
    I’m new to this HDV stuff and need to dig in further about audio settings. However, I appreciate the suggestion and will give it a try.
  • Steven L. gotz
    January 6, 2007 at 8:27 pm
    I watch a lot of television after my wife goes to bed. I do a lot of editing after my wife goes to bed.
    So, I am sensitive to changes in volume levels. I don’t want to use headphones and I don’t want to wake her up.
    I decided after some research, that if I settled on a peak of -6dB with the occasional transient up to -3dB, I would be able to switch from a professionally mastered DVD to one of my DVDs and not have a big change in levels. And if I changed to most TV stations, the same thing applies.
    Not very scientific, but it works for me. Average peaks of -6dB.
    Steven
    https://www.stevengotz.com
  • Payner44
    January 6, 2007 at 8:39 pm
    Just tried a WMVHD export with the timeline audio set to -6db and the resulting file was fine…thanks!!
