Audio Disaster at Live Event – Line vs Mic
Elijah Lynn replied 17 years, 6 months ago 8 Members · 21 Replies
Elijah Lynn
February 18, 2009 at 12:58 amAs Ty said, the attenuators on the camera won’t knock it down that to that degree. Here are the Hosa attenuators I have. They are not the highest of quality and one of them had it’s screws loose underneath the sticker that I had to tighten so the switches worked properly. I like these because they do -20, -30 and -40 db and you can use them in conjunction with the built in camera attenuators to get a total arsenal of 6 different attenuation levels.
I needed them quick and they worked well. I am glad to have them in my gear collection.
If a camera can knock it down it will usually have a settings for “mic level” or “line level” for its inputs. Normally found on high end cameras.
Cheers,
