Activity Forums Adobe Premiere Pro Audio Desync’ing Issues
  • Audio Desync’ing Issues
    Posted by Aznlemming on March 13, 2006 at 7:46 am
    I recently started using Premiere to put together some video files I had lying around on my computer. They’re all at 30fps, and the sound syncs just fine. However, after putting it through Premiere (Rate changes, etc., and added a “global” music track) the audio desyncs from where I wanted it. Neither the original audio track, nor the “global” music track are where they should be.
    It seems that the audio is all right near the beginning, but toward the end, the audio’s way off. I’m guess it has something to do with the frame rates, but I have no idea how to remedy the problem. Any suggestions would be most appreciated. Thank you.
    -Glen
    Aznlemming replied 20 years, 6 months ago 2 Members · 3 Replies
  • Sameer Shrivastava
    March 13, 2006 at 10:29 am
    Is every thing in your time line rendered ? just play the sound without video(video track off) and listen if sound drops or skips or changes speed.
    good luck
    bye
    sameer
  • Aznlemming
    March 13, 2006 at 11:31 am
    Yeah everything’s rendered. I tried what you suggested, and everything sounds like it should. Additionally, if I play the rendered movie in the preview window with the sound, the sound is sync’ed up with the video…
  • Aznlemming
    March 14, 2006 at 9:01 am
    OK, so I just realized my project is in 29.97 fps… I’m guessing this might have something to do with the problems? If so, is there a way to convert it back to a 30 fps project, or do I have to start over from scratch?
