Activity Forums Apple Final Cut Pro Legacy Audio Delay Problem
  • Audio Delay Problem
    Posted by D. Gregor hagey on February 2, 2009 at 8:48 pm
    I’m having a 10 to 12 frame audio delay on playback of a feature length project. I can see that the audio waveform is in sync on the sequence timeline, but it doesn’t playback in sync. I’m running FCP 6 on a dual Quad Xenon with 10.5.6. I’m monitoring picture and audio with the Kona LHe card.
    Gregor
    Gregor
    D. Gregor hagey replied 17 years, 6 months ago 2 Members · 2 Replies
  • John Fishback
    February 3, 2009 at 8:08 pm
    If you have many audio tracks try an Audio Mixdown (Sequence>Render Only >Mixdown) and see if that helps. Have you trashed prefs and rebuilt permissions?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • D. Gregor hagey
    February 4, 2009 at 7:27 am
    Thanks. Trashing the prefs worked.
    Gregor
    Gregor
