Activity › Forums › AJA Video Systems › Audio delay issue just started happening
  • Audio delay issue just started happening
    Posted by Dan Riley on August 6, 2008 at 5:25 pm
    Setup:
    KONA 3 driver 5.1
    OS 10.5.4
    FCP 6.0.4
    About a week ago, all the sudden, whenever I start up FCP, the audio
    will be out of sync coming out of the KONA card to my audio monitors
    relative to the video out of the KONA card on my video monitor.
    The audio is also out of sync with the canvas or viewer on the computer monitor.
    The audio will be late by more than a few frames.
    This happens on both SD and HD formats and sequences.
    The way I fix it is to go to easy setup and just re-apply the setup it already
    is set for. There will be a slight jump on the video monitor.
    Then the audio and video match up again on the output.
    Any help would be appreciated.
    Dan
    Dan Riley replied 18 years, 1 month ago 2 Members · 2 Replies
  • Walter Biscardi
    August 11, 2008 at 12:22 pm
    What is your Playback Offset set to? It should be 0
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Dan Riley
    August 12, 2008 at 11:07 pm
    Yes, it’s at zero.
    This is the strangest thing. Every time I start up FCP, either from a dead systems startup,
    restart or from and FCP close and open… each time I do that, If I start playing back
    a sequence, the audio will be off by more than a few frames (audio will be late)
    on both SD and HD sequences and projects.
    I go up to easy setup and re apply the setting it’s already at, I see a blink on the
    NTSC and/or HD monitor, start the sequence playback again and it’s fine now.
    Maybe trash prefs? I’ve looked all over the AJA card settings and don’t see anything
    unusual there as far as I can tell.
    Dan
