  • Posted by Adrian Stirbu on February 10, 2010 at 6:04 pm
    hi there guys
    i am having a bit of a weird problem with my audio in final cut, almost every time i try adding my sound that is recorded on an external device in final cut at the begining it work just ok with the sound from my camera but after a while i get a delay in sound and it get unsynchronized i have tried many options altering the bit rate and the sample rate to have it exactly as my sequence but still it doesnt work. can anyone pls help me. this stuff is driving me crazy.
    John Fishback replied 16 years, 7 months ago 3 Members · 3 Replies
  • Michael Gissing
    February 10, 2010 at 9:15 pm
    Can you tell us what the separate audio recorder was, the file type recorded, timecode or not, timecode type (ie PAL/ NTSC DF non drop),plus the video file information, including frame rate and timecode type.
    Then we need to know the sequence settings including frame rate, timecode settings and audio sample rate. This is the basic information needed to help solve your problem.
    Please also think about basic punctuation. Your post is hard to read.
  • Adrian Stirbu
    February 10, 2010 at 11:07 pm
    1st of all i would like to say that english is not my first language so i apologize for my spelling mistakes.
    I am using the video footage from sony pmw ex3 cameras, PAL settings 720/50p, the external audio device is an ediroll it records in wav format. when i drag the clip in the timeline i click yes for the sequence to be modified to the clip settings.
  • John Fishback
    February 10, 2010 at 11:41 pm
    Is your Ederol recording at 48k sample rate? If not, open the audio file in QuickTime Pro or an app like MPEG Streamclip (free, if you’re not familiar with it) and export the file with the sample rate set to 48k (16 or 24 bit). Then import that file and see if it syncs.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
