Activity Forums Adobe Premiere Pro Audio de-sync issues
  • Audio de-sync issues
    Posted by George Rupp on June 21, 2019 at 5:33 am
    Hi there,
    I’ve been using premiere for a few years now and I’ve frequently ran into this problem. When adding footage into the timeline (of significant length) I notice that by the end of the recording the video and audio become miraculously out of sync with each other despite not altering it in any way. I have not yet found a solution to the problem, though I suspect its something wrong with my settings as this issue always occurs and isn’t random.
    The only solution I found has been to continuously cut and realign the audio to match the footage. any help would be appreciated.
    Keep in mind when I play the original video files back through media player the audio remains synced correctly. ive attached my sequence settings (in case that’s useful.)
    Todd Perchert replied 7 years, 3 months ago 4 Members · 5 Replies
  • John Pale
    June 21, 2019 at 12:29 pm
    What footage are you using that is 60fps and uses 44.1 kHz audio? Both are unusual.
  • George Rupp
    June 21, 2019 at 12:54 pm
    Sorry I uploaded the wrong screenshot, this is the correct version:
    it was iPhone footage. These settings are the settings premiere automatically pics.
  • George Rupp
    June 21, 2019 at 12:57 pm
    sorry again, THIS is the correct screenshot.
  • Jon Doughtie
    June 21, 2019 at 1:46 pm
    If you shot with the iPhone-included camera, that’s the issue. It records variable frame rate. No edit app really likes it.
    One immediate solution to fix your current issue: download Handbrake (https://handbrake.fr/) and convert the footage to a constand frame rate MP4 file. Then it will behave in your edit timeline.
    For the future: look in the app store for a camera app that records constant frame rate, and it will not bite you again.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Todd Perchert
    June 21, 2019 at 2:23 pm
    So that’s your sequence settings, what is your original media? File container, codec, frame rate? And what hardware did it come from. If phone, then Jon has your answer.
    TC
