Activity Forums Adobe Premiere Pro Audio Cuts Out
  • Audio Cuts Out
    Posted by Joel Hebert on November 24, 2011 at 10:46 pm
    Im editing a video in premiere pro cs4 on a macbook pro. All the video came from a Motorola Atrix camera phone (960×540 HD, 29.97 fps, .mp4 file). In every single clip I imported, the audio cuts out after about 2 seconds (no wav form bars in the timeline display either)? Whenever I playback the .mp4 in Quicktime the audio and video play just fine? Any help would greatly be appreciated.
    Joel H.
    Paul Neumann replied 14 years, 10 months ago 2 Members · 1 Reply
  • Paul Neumann
    November 25, 2011 at 5:15 am
    I’d try two or three things:
    Assuming you have CS4 and not just Premiere Pro, right click on the audio track and choose edit in Soundbooth/Render and Replace. See if the entire track loads up in SB and if it does then just resave it and it will replace it on your timeline.
    Load the clips into After Effects and export them and reload them into PPro. Sometimes those camera phone codecs are just flakey. You could try this with just AME as well.
    Make sure you don’t have audio set up to quit outputting sound if the level clips too hard. One of those bite you in butt settings that serves a purpose AND gives you fits at that same time.
