Activity Forums Apple Final Cut Pro Legacy Audio cuts out
  • Posted by Andy Hutchinson on April 25, 2005 at 5:33 am
    I am adding music and vocals to my timeline and at one point on the timeline it cuts out for about three frames and then resumes when I am playing it on the timeline. It doesn’t matter what type of music it is. It is doing it with Sonic Fire, buyout, and even copyrighted music from a CD. I can shorten it and it will do it everytime at the same point. It plays perfectly from the Viewer. If I move the playhead three frames to the right of the point it plays perfectly. I locked the four tracks I am using and hit delete to see if there was a sliver hidden somewhere and still the same. I created a new sequence and copied each track one at a time and still the same thing happens.
    Ideas?
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
    OS-10.3.7, FCP4.5, SP 2.05, Dual 2.5 G5, 2 gigs RAM; Sys HD 200G : WD 200G 7200rpm with 8 Meg buffer; 2 WD 250G 7200 rpm with 8 Meg buffer FW enclosure; Lacie FW800 card; Maxtor 120G FW for storage, 1 WD,
    Andy Hutchinson replied 21 years, 4 months ago 3 Members · 4 Replies
  • Andy Hutchinson
    April 25, 2005 at 5:35 am
    One other thing. The wave meter shows it is there and the audio meters are showing it is playing at this spot too.
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
  • Matt Murray
    April 25, 2005 at 10:31 am
    Hey bud, have you mixed down all your audio?
    Sequence/Render Only/Mixdown.
    Make sure you have all your audio tracks selected.
    How you liking the new computer so far?
    Mine is a working monster, love it.
    Matt Murray
    Lineside Productions
    Wellington, FL
    https://www.edgesportfishing.com
    Florida Sailfish videos, pictures and more
    My World Video Productions
    Mac OS X 10.3.7 , QT 6.5 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD, DVDSP 3.02, Compressor 1.2.1, Motion 1.01
  • Chris Babbitt
    April 25, 2005 at 2:20 pm
    Andy,
    You probably have a little glitch or disturbance in your video. Oftentimes, when this happens, for some reason, you’ll get an image but audio will not play over the firewire at that spot. You’ll get audio if you export to a DVD, but not out to tape. Take another look at your video at that point, and I’ll bet that you’ll find a little disturbance in the picture. Go back and look at your source footage, and if you don’t see it there, recapture. If not, see if you can find a cutaway to replace that piece or eliminate it all together. It’s probably only a few frames of video.
  • Andy Hutchinson
    April 25, 2005 at 5:54 pm
    I did the mixdown and it was till skipping. The tape is a DV tape and may have a dropout but I didn’t see anything. So I cut the video at the point where the skip started and ended up shortening the video by four frames. I was able to work out the video so it wasn’t noticeable and it sounds perfect now. Thanks for both your help.
    Wonder what causes this?
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
