Activity Forums Adobe Premiere Pro Audio cut short after import
  • Audio cut short after import
    Posted by Matthew Rowley on February 21, 2011 at 6:47 am
    Occasionally PPCS3, after import, will cut short an audio track I wish to use. This has generally occurred when importing music from albums by professional artists.
    Am I causing the program to interpret the audio track incorrectly, or is this a bug that needs fixing?
    I appreciate the help.
    Matt
    Matthew Rowley replied 15 years, 7 months ago 1 Member · 1 Reply
  • Matthew Rowley
    February 21, 2011 at 6:56 am
    On this particular project, I was importing an .m4a. The audio itself would be cut short, but the track length would remain the same.
    I created a .wav version of the song and re-imported it, and CS3 recognized the last couple of seconds. The song played like it should have originally.
    If anyone understands why this occurred, I would appreciate an explanation. Thank you in advance.
    Matt
    Sony EX1R
    Adobe CS3
    abdielpictures@gmail.com
