Activity Forums Adobe Premiere Pro audio cut and paste issues – Help
  • audio cut and paste issues – Help
    Posted by John Martinez on May 30, 2007 at 5:42 pm
    I was working on a project in Adobe Premiere Pro when I realized the resolution was not the best size so I copied the video and audio pieces from the file I was working on, opened a new file at the right resolution, then pasted the audio and video pieces into the new file. I then worked on the project (it worked fine), saved it and shut the machine down.
    Now, when I reopen the file, I get no audio from the pasted audio, audio/video clips. I can SEE the audio information when I look at the audio clip up above in the source window, but when I zoom into the audio timeline, there is no audio information.
    when I import another audio clip everything works fine.
    Any ideas?
    Vince Becquiot replied 19 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • John Martinez
    May 30, 2007 at 5:59 pm
    Vince, thanks for the quick response. Can you help me further clarify:
    You say “Find your peak files folder (the location is under Preferences), and delete them.”
    Can you help me dig down a little deeper? When I go to preferences, what option should I choose?
    I could not find a folder called “peak files folder”. Is there some other name? Alternatively, I can search by file extension. What file extension does a peak file use?
    Thanks for the help. It is greatly appreciated.
  • Vince Becquiot
    May 30, 2007 at 6:25 pm
    Vince
  • Vince Becquiot
    May 30, 2007 at 10:49 pm
    Look for Preferences > Scratch Disks > Audio previews
    If you haven’t changed the default scratch disks, the peak files should be in a subfolder named “Media Cache Files”, in your project folder. Delete all the files in that folder. Let us know how that works out.
    Cheers,
    Vince
  • John Martinez
    May 30, 2007 at 10:56 pm
    Thanks. Does that only work for the files before they are placed in the timeline? After I erased the .pek files, then relaunched my project, Primiere went through and configured all my audio in the project bins but did not update what I had already placed on the timeline. The audio files continue to flat line.
    Is there a solution or am I just stuck doing everything over?
    Thanks.
    John
  • Vince Becquiot
    May 30, 2007 at 11:05 pm
    That affects every files in your project. If you deleted the right peak files, Premiere should start conforming again within a few seconds. Look around in case you moved the project.
    Also, if Premiere crashed, and you are using an autosaved file, the peak files will be in a subfolder in the autosave folder.
    Vince
  • Vince Becquiot
    May 30, 2007 at 11:09 pm
    One more thing, I don’t know how many projects you are working on, but you can do a windows search for “.PEK” and see what folders/files come up. Then delete away !
    Vince
  • Vince Becquiot
    June 3, 2007 at 4:50 pm
    I meant to add that, if that converter did introduce errors in the file, Premiere Pro would be a lot more picky about it than Vegas, or even Premiere Elements I believe.
    Vince
