Activity Forums Adobe Premiere Pro Audio crackles with multiple layers.
  • Audio crackles with multiple layers.
    Posted by John Davies on October 20, 2017 at 9:12 am
    Just stumbled across a new issue in Premiere CC 17 (11.1.2)
    Whenever I have more than one audio track running, I get a crazy crackle sound. As soon as it’s back to down a single track, the crackle finishes. Also happens with Constant Power fade between tracks on the same layer.
    The audio is coming from a multi-cam sequence. Could this be the root of the issue?
    Has any one had anything similar before? Thanks in advance!
    John Davies replied 8 years, 11 months ago 2 Members · 2 Replies
  • Eric Merklein
    October 20, 2017 at 1:09 pm
    Hi John.
    Could it be that when you have 2 tracks playing at the same time the audio level hits the roof and the crackling is actually distortion?
    Just a thought.
    E
  • John Davies
    October 20, 2017 at 1:46 pm
    Hi, I think I found the problem.
    One of the 12 multi-cam tracks had 4 layers of audio. 3 were muted and 1 was the main audio for the edit. I deleted the muted layers just to tidy the project up a bit and it seems to have stopped. Hopefully that was the cause of the problem.
