Activity Forums Adobe Premiere Pro Audio Crackles when Export from PPro CS3 to Encore.
  • Audio Crackles when Export from PPro CS3 to Encore.
    Posted by Justin Hawley on September 24, 2011 at 5:00 am
    Hello all,
    I have a HD 720P nested sequence I am trying to export to DVD. I have limiter filters (-.20 I believe) on both the original sequences as well as the final nested sequence. Nothing peaks in the red on any sequence that I can see.
    However, when I export this to DVD I get this jittery, crackly audio and I can’t figure out how to fix it.
    I have also tried reducing the bit rate. I believe the most recent one was 3.0 target and 5.0 max. That didn’t work either.
    I really am in a pinch here. My deadline is coming very soon and I need someone with knowledge to help out. I’m on a Vista 64-bit Sony Vaio. I have burned DVDs from this machine successfully in the past.
    Thanks for your help in advance,
    Justin.
    Vince Becquiot replied 14 years, 12 months ago 2 Members · 1 Reply
  • Vince Becquiot
    September 24, 2011 at 8:21 pm
    Hi Justin,
    My guess is your problem is the limiter. Easy to figure out, turn it of and do a short test export to Mpeg2 DVD and listen to the wav file.
    I never use the Premiere hard limiter, the compressor (part of dynamics plugin) is a much better option.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
