Activity › Forums › AJA Video Systems › Audio Crackle
  • Audio Crackle
    Posted by Greg Jones on June 9, 2005 at 2:43 pm
    Has anyone else had a problem with Audio Crackling from their Kona2 card? I’ve noticed since upgrading to the latest drivers that I’m having issues with audio crackling. I’ve looked through some older posts and noticed other people have had this problem before. Does anyone know of a work around?
    Greg Jones
    D7,inc.
    Orlando,Fl.
    Greg Jones replied 21 years, 3 months ago 2 Members · 2 Replies
  • Christopher Tay
    June 9, 2005 at 4:06 pm
    Where is the crackling coming out from ? Are you using the K-BOX ? If you are, check the Genlock setting in the Kona Control Panel…if it’s set to Video Input and there’s no video input source, you will hear crackling coming out of the analog output of the K-BOX. Just set it to Freerun and it’ll go away.
    Did you update the firmware on the Kona 2 card when you updated the driver ?
    -chrispy
  • Greg Jones
    June 9, 2005 at 4:42 pm
    When I put the genlock to free run it fixed the problem. I do have a K-Box. Thanks for the advice.
    Greg Jones
    D7,Inc.
    Orlando,Fl.
