Activity Forums Apple Final Cut Pro Legacy audio control surface problem
  • audio control surface problem
    Posted by David Page on July 4, 2015 at 4:09 pm
    Got aan Akai midimix control surface to control audio in FCP 7. Computer sees it but i can’t get it to control levels. Can someone run me thru necessary settings?
    Nick Meyers replied 11 years, 1 month ago 2 Members · 1 Reply
  • Nick Meyers
    July 5, 2015 at 8:57 am
    i havent done this in a while, and this is from memory:
    in FCP< go to Tools Menu > Control Surfaces
    click on the plus button to add a new control surface,
    you have to specify the protocol.
    are you sure that AKai will work with FCP?
    nick
