Activity Forums VEGAS Pro Audio compression in Architect 4
  • Audio compression in Architect 4
    Posted by Joe Gaziv on November 18, 2007 at 8:35 pm
    I’ve noticed Architect 4 almost always compresses my audio and I do not understand why. I render in Vegas 7 using PAL DVD template (which generate MPEG 2 AC-3 audio (Stereo) 48Khz sampling) with bit rate of 224Kbps which, to my understanding should not get recompressed while burning PAL DVD with Architect 4. Any reason why is that?
    Joe Gaziv replied 18 years, 9 months ago 3 Members · 6 Replies
  • Edward Troxel
    November 18, 2007 at 10:24 pm
    Are you rendering the AC3 separately? If not, you’re actually rendering MPEG audio which must be uncompressed and then recompressed as AC3.
    Edward Troxel
    JETDV Scripts
  • Joe Gaziv
    November 19, 2007 at 6:10 am
    [jeditdv] “Are you rendering the AC3 separately?”
    No, I do not render separatly. I rechecked myself and I made a mistake in my post – Sorry for that. Here is the correction – My native current clip is .m2t (which has stereo audio). I render to PAL DVD STD template. Then I burn PAL DVD using the Architect.
    I am getting a comment, before it gets burned, saying the audio has to be compressed.
  • Edward Troxel
    November 19, 2007 at 5:17 pm
    That’s true. It has to be decompressed from the .m2t file and then recompressed into AC3 format.
    Edward Troxel
    JETDV Scripts
  • Joe Gaziv
    November 20, 2007 at 5:39 am
    But does’t it happen when I render in Vegas? Why is it needed, again, in Architect?
  • Douglas Spotted eagle
    November 20, 2007 at 5:45 am
    Because the template to which you are rendering isn’t supported for DVD delivery of MPEG. Computers, yes. DVD, no.
    You want to make it easy, use the VASST freeware “DVDPrep.” It’ll make the MPEG and AC3 file using the same name/folder, and it’ll make it faster for you in Architect.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Joe Gaziv
    November 20, 2007 at 11:48 pm
    Thx Spot – A great SW!
