Activity › Forums › Compression Techniques › Audio codecs and video bitrates in Compressor 4
  • Audio codecs and video bitrates in Compressor 4
    Posted by Jake Shepherd on June 10, 2013 at 3:43 pm
    Hello.
    I have edited a short film using FCPX and have just bought Compressor 4 to export the video file.
    One of the festivals that I am submitting the film to requires very precise export settings.
    Can anyone suggest how I can export the audio as a Mpeg-4 AAC LC codec and select a bitrate of 821kbps for the video? I can see that there is a ‘restrict to’ datarate option for the video. Can this be treated as a way of selecting bitrate? I have also searched online to download a low complexity audio codec with no success.
    Any help would be much appreciated.
    Many thanks.
    Jake
    Craig Seeman replied 13 years, 3 months ago 2 Members · 5 Replies
  • Craig Seeman
    June 10, 2013 at 4:40 pm
    I believe Compressor gives you a choice between HE-AAC and AAC. I think the latter is AAC-LC but, like much of Apple’s documentation and UI, they keep this information hidden.
    In Compressor 4 I see:
    AAC
    MPEG-4 AAC Enhanced Low Delay
    MPEG-4 AAC Low Delay
    MPEG-4 HE AAC
    MPEG-4 HE AAC V2
    It’s difficult to hit a precise data rate. You can target (or restrict) to it but there’s some degree of over/under depending on the content. CBR encodes tend to hit a target more closely more often but they also are often lower quality.
  • Jake Shepherd
    June 10, 2013 at 4:51 pm
    Is that a general rule that it’s hard to hit a precise data rate? Or just for Compressor? If I used a different program in conjunction with FCPX could I get precisely that bitrate?
    The audio codec requested is MPEG-4 AAC LC. Would you say that MPEG-4 AAC Low Delay is an equivalent?
    Many thanks Craig.
  • Craig Seeman
    June 10, 2013 at 5:02 pm
    [Jake Shepherd] “Is that a general rule that it’s hard to hit a precise data rate?”
    Yes, it’s the nature of encoders IMHO. Some are more accurate than others depending on the underlying analysis.
    [Jake Shepherd] “The audio codec requested is MPEG-4 AAC LC. Would you say that MPEG-4 AAC Low Delay is an equivalent?”
    No.
  • Jake Shepherd
    June 10, 2013 at 5:20 pm
    Thanks.
    Do you happen to know if low complexity audio codecs are available to download and use in Compressor 4?
  • Craig Seeman
    June 10, 2013 at 5:48 pm
    As per my previous post I believe AAC is AAC-LC. It’s not documented though in my checking.
