Activity Forums Broadcasting Audio Codec for TV Broadcast
  • Audio Codec for TV Broadcast
    Posted by Kevin Reinicke on January 30, 2009 at 3:16 pm
    Hey guys,
    I have to deliver a music video and the channel wants me to send them a high quality quicktime file (no more informations) of it.
    I was asking myself which audio codec would be best for this, PCM (44.1k or 48k?) or other?
    I tested a bit and burned some tracks on DVD and the AAC codec audio file sounded best.
    what do you guys think abt this?
    Micah Mcdowell replied 17 years, 6 months ago 3 Members · 5 Replies
  • Tim Ward
    January 30, 2009 at 7:07 pm
    [Kevin Reinicke] “the channel wants me to send them a high quality quicktime file (no more informations) of it.”
    If that’s all the information they’re giving you, then they obviously don’t care. 48kHz PCM is pretty standard for audio, but if they have delivery specifications–meaning they give specific requirements, and not just “a high quality quicktime file”–then go by those.
  • Kevin Reinicke
    January 31, 2009 at 10:34 am
    No they didnt give me anymore info.
    so AAC codec should be fine?? What you guys think abt this codec?
  • Tim Ward
    February 4, 2009 at 2:33 pm
    [Kevin Reinicke] “No they didnt give me anymore info.
    so AAC codec should be fine?? What you guys think abt this codec?”
    I’d ask them again for detailed delivery specs. Don’t do AAC, do PCM (uncompressed). This is a MUSIC video where the AUDIO is the focus, so don’t slack on the audio at all. Give the station the best they can take (which 48kHz PCM should be fine).
  • Kevin Reinicke
    February 4, 2009 at 6:42 pm
    Tim,
    as I said I liked the AAC codec better. I burned both a version with PCM and AAC on DVD and tested on different TV´s.
    I dont know if that is normal. I showed it to the artists too and they liked the AAC Version better too.
  • Micah Mcdowell
    February 12, 2009 at 11:24 pm
    AAC is a lossy codec (you lose a little quality no matter what), while PCM is lossless (it is the exact information from the original source, with no compression). If AAC sounds better to you, then you’re either perceiving a difference that isn’t there or there’s something wrong with your settings (leave it at PCM 48k uncompressed). Plus, PCM works in everything, while occasionally (though rarely) AAC will have compatibility issues.
