Activity Forums Apple Final Cut Pro Legacy Audio clips going offline when ROUNDTRIPPING to SOUNDTRACK PRO
  • Audio clips going offline when ROUNDTRIPPING to SOUNDTRACK PRO
    Posted by Steve Heffner on April 18, 2009 at 8:47 pm
    Hey all,
    THis is making me crazy. Haven’t encountered it before. I’m sending audio clips to Soundtrack Pro for repair/noise removal. I’m doing SEND TO because we aren’t mixing in FCP. One clip worked and the rest come back saying OFFLINE and the file it looks for says RENDER after it. I tried to do a workaround and reconnect to the actual STP “sent” audio project file and it says “this audio file does not contain enough tracks to reconnect”. Which “sorta” makes sense because I’m only using he left track in the cut.
    I tried making the clips independent, etc. One seemed to work but came back in out of sync. All clips are from same project, same camera (all P2 files), etc.
    Hope this makes sensee.
    Any help appreciated. THANKS.
    Steve Heffner replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
