Activity Forums Audio Audio Clipping when levels look good
  • Audio Clipping when levels look good
    Posted by Cory Lusk on September 18, 2015 at 2:02 pm
    I shot a Stevie Ray Tribute band, and I connected the zoom H4n, to the sound board. I made sure to check the levels, and listen with the headphones. I left the device at shot the show. Afterwords when I listen to the audio it sounded like it was clipping constantly, but I checked the levels and they seems good. I have adobe audition and I’m not sure what tools to use to fix this. here is a link to the audio, any help would be much appreciated it!
    https://www.youtube.com/watch?v=Tx41XRrqLME
    John Fishback
    replied 11 years ago
    6 Members · 5 Replies
  • Richard Crowley
    September 18, 2015 at 3:50 pm
    Just because the levels at YOUR gadget were OK doesn’t mean that they weren’t “pre-clipped” up-stream somewhere at a previous link in the audio chain. It is not uncommon to set levels during rehearsal only to discover that the actual live performance significantly exceeds what you though were safe levels.
  • Ty Ford
    September 19, 2015 at 6:49 am
    Hello Cory and welcome to the Cow Audio Forum.
    Richard’s spot on and welcome to Audio Rule 1.02, never leave the audio unattended. When? NEVER?
    Audio Rule 1.01, BTW is, When do you listen? Always. Really? Yes, ALWAYS!
    The person running the mix serves the band, he’s not YOUR mixer. Levels will most likely change and most likely increase if it’s a live music mix.
    Sorry you had to learn the hard way, but you’ll never make that mistake again.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Brian Reynolds
    September 19, 2015 at 9:58 am
    How was the recorder connected to the house mixer XLR’s or the 6.5mm sockets?
    What the connection Aux or Matrix or Main Output (XLR) or RCA?
    What was your input level set at?
  • Chris Wright
    September 20, 2015 at 3:39 am
    if you leave it, make sure that you have an inline compressor like ratio 3:1 or a smart limiter. You can always uncompress, you can’t recover clipping.
  • John Fishback
    September 21, 2015 at 1:18 am
    Depending on the amount of clipping you can de-clip with iZotopeRX.
