Activity › Forums › Apple Final Cut Pro Legacy › Audio Clicking
  • Posted by Dan Archer on September 25, 2007 at 11:59 pm
    Hell Cow folks. Got one i dont understand. Am working on a FCP 5.1.4 on 2xIntel dual core zenon. Captureing from digi beta thru Kona 3 usiong SDI. On playback Al i get audio wise is a cyclical clicking noise that sounds like 2 or 3 frames being looped over and over……..
    I know its a one switch thing i just cant figure it out. Any ideas. Thanks for any help in advance.
    Jason Lyons replied 19 years ago 2 Members · 3 Replies
  • Jason Lyons
    September 26, 2007 at 5:37 am
    Good Morning!
    Not sure what you have tried, but…
    1) Power down, go start a pot of coffee, power up & try again
    2) Verify you have the latest AJA drivers & try again, go grab some fresh air
    3) Make sure you are set up via AJA control panel for AES over BNC
    4) Run Easy Setup for your configuration fix a cup of coffee & try again
    5) Verify you are using an appropriate 75 ohm SDI cable & try again
    6) Hopefully someone will confirm this, but I am fairly certain that you dont have the option on Digibetas to sample at 44.1k, if so make sure your sample rates just trying to think of everything…
    good luck
  • Dan Archer
    September 26, 2007 at 1:19 pm
    Cant seem to find number 3 in control panel. where should i look? It seems that may be a good place to start
  • Jason Lyons
    September 26, 2007 at 2:15 pm
    Reference page 44 in the manual. Its under the input tabs.
    j
