Activity › Forums › Adobe After Effects › Audio Channel fill?????? Please!
Posted by Todd Schmidt on October 13, 2011 at 8:20 pmHi all,
Question. I have footage shot with audio in one channel through an XLR mic. I need it to be stereo…
In Premiere I use the fill effect to fill in and make stereo. How is this done in After Effects? I’ve produced the spot now I have one channel with VO and the stations won’t air it unless I have stereo.
Please!!! This is urgent!
Todd
Chris Tompkins replied 14 years, 11 months ago 4 Members · 8 Replies -
Walter Soyka
October 13, 2011 at 9:04 pm[Todd Schmidt] “I have footage shot with audio in one channel through an XLR mic. I need it to be stereo… In Premiere I use the fill effect to fill in and make stereo. How is this done in After Effects? I’ve produced the spot now I have one channel with VO and the stations won’t air it unless I have stereo.”
Why not bring it into Premiere and do it like you normally would?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Todd Schmidt
October 13, 2011 at 9:19 pmActually, that’s what I’m doing and importing my premiere project into AE. Each clip gets the stereo mix effect on it but it doesn’t duplicate the audio. I’m still getting one channel.
Butch Golden
October 14, 2011 at 4:54 amAudacity can convert your audio track to stereo. Export audio only in Premiere then go (here) and follow the tutorial. Sony Sound Forge will also do this in much the same manner. Audacity is a free editor you can get from audacity dot com.
Butch Golden
October 14, 2011 at 5:14 amI should add that you can use the ‘Export’ function in the Audacity ‘File’ menu to save as a Windows .wav file and drop that into your Premiere timeline.
HTH -
Butch Golden
October 14, 2011 at 5:19 amSorry,
the Audacity link is https://audacity.sourceforge.net/ -
Todd Schmidt
October 15, 2011 at 1:56 pmThanks Butch,
I know there are ways around it by exporting audio, clips as movies using the fill effect on audio, etc. My problem is I’m trying to avoid this because I feel it’s a waist. I edit in Premiere making a skeleton then importing my project into AE for final effects. AE won’t import the fill effect. Just thought there would be a simpler way of doing this.
Todd
Walter Soyka
October 16, 2011 at 3:06 pmYou could use AE’s Stereo mixer effect [link].
If you’re going to bounce out to Audacity anyway, you might try some pseudo-stereo [link], which may or may not fit your source material nicely.
Walter Soyka
Chris Tompkins
October 16, 2011 at 4:10 pmYou can right click on your audio tracks in APP b/4 you drop them into the sequence and change the audio from mono to stereo, etc…
Chris Tompkins
Video Atlanta LLC
